idle problems
Old May 20, 2004 | 04:41 PM
aberlinetta84's Avatar
Car: 84 Berlinetta
Engine: 305 LG4
idle problems
I have a question, I have an 84 berlinetta 305 V8, It normally runs fine, but lately sometimes it will not idle...It starts right up then dies....and other times, it idles and drives just fine. Need help its driving me crazy
Old May 20, 2004 | 05:29 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Is the choke in full operation?
Old May 20, 2004 | 05:38 PM
Car: 84 Berlinetta
Engine: 305 LG4
any easy way to find that out? Is the PCV supposed to rattle?
Old May 20, 2004 | 06:06 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Im not the most proficient as to how the choke itself works, but it sounds like it may be sticking closed at times. Perhaps others can shed light on that.
As for the PCV, a operational PCV has a little valve inside it that is supposed to rattle. So yes, if it rattles it is good.
Old May 20, 2004 | 08:41 PM
Car: 84 Berlinetta
Engine: 305 LG4
does a tbi have an idle air control? or what takes place?
Old May 20, 2004 | 08:46 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
yes, TBI systems have the IAC. However, if your engine is the LG4 like in your info, then you have the 305 with a carburetor. Unless you swapped to TBI...
Old May 20, 2004 | 10:12 PM
Car: 84 Berlinetta
Engine: 305 LG4
I have narrowed down the problem by swapping my girls carburetor (I love having camaro clones :-)..) with mine, could it be the EGR valve? and if so can I just rid the engine of all smog equip, I kind of like hers better lol
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
