Rough idle at times
Old May 21, 2004 | 09:30 PM
zuby1000's Avatar
Car: 87 Z28 CANDY APPLE RED
Rough idle at times
I recently put a rebuilt engine in my 87 camaro tpi and got most of the bugs out and got it running finally. I had idle issues ever since i put it in, but finally got it to the point where it stays running. However, sometimes when i come to a light and sit for a min or two, it will all of the sudden start idleing real rough and the o2 sensor light will come up, once in a while stall, but usually after a few seconds of this it will idle smooth again. Then after about 10 secs of driving again the light will go off and everything will be fine. Does anyone have any ideas what this could be? Thanks
Old May 21, 2004 | 09:44 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
The O2 sensor light? I'm assuming you get a check engine light, and you pulled the code and it was an O2 code. In that case, is it a rich or a lean code?
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Bradsaundry
Aug 12, 2015 12:34 AM
