over heat?
Old May 21, 2004 | 10:01 PM
Lucky 13's Avatar
Car: 89 RS
Engine: 305 TBI
over heat?
i am not sure if my temp gauge is working properly. i have noticed iget warm in the cabin with windows down cruising. and my engin compartment is rather hot. my car sat yesterday for two hours after i drained the oil, and the valve covers were almost too hot to touch. but my temp guage is reading between 170 and 200. varies because of virginias wack weather.
should i replace the sending unit? I am just concerned that i am running real hot an not even know about it.
Old May 21, 2004 | 10:16 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
I think I have the same problem. I don't have a temp gauge so I can't tell. But I do notice that my rad fan is NEVER running.
Old May 21, 2004 | 10:26 PM
AM Racer's Avatar
You're looking for a non problem.
Put a thermometer in a pot of water.
Heat until between 170~ 200. Try to touch it. (Keep cold water ready).
Also, the coolant temp is generally lower than the rest of the engine.
Old May 23, 2004 | 02:07 PM
Lucky 13's Avatar
Car: 89 RS
Engine: 305 TBI
yeah i understand that 170-200* is hot, but i used to be able to rest my hand on the vlave cover while leaning over the engine bay, a few hours after it has been shut down.
i dont have a fan problem, as i have a hayes adjustable switch hooked up to come on around 160-170.
Old May 23, 2004 | 02:11 PM
RebelTillDeath3's Avatar
Car: 92 Camaro
Those temperatures seem normal...........
Old May 23, 2004 | 02:48 PM
ede's Avatar
ede
you engine, or valve covers would be hot in the summer weather and running the engine will only add to the heat. i don't think you have a problem, but if you want to feel better take a few readings with a temp gun or change your sender.
Old May 24, 2004 | 03:14 PM
Lucky 13's Avatar
Car: 89 RS
Engine: 305 TBI
i figured that is probably what i would end up doing. thanks for the help
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
