Need help with the emergency brake.
Old Mar 26, 2001 | 12:59 PM
Tec21-CamaroLover's Avatar
I'm in the middle of tightning my E-Brake and i can't figure out which way to turn the nut on the adjusting screw. I have Drum Brakes on my '86 Camaro. I think i tightened it too much, ...
It's an Automatic.. would the car being in park affect the rear wheels?
'86 Camaro
2.8 MPFI
Old Mar 26, 2001 | 01:12 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You tighten the nut in the direction that makes it screw farther onto the rod, so that it pulls the half-moon shaped thing oward the front of the car.
If you over-tighten it, your rear brakes will drag, and will burn up. Set it so that after you adjust the rear brakes up as high as they'll go and you can still get the drums back on, the parking brake (it's not an emergency brake) handle will pull up about 3 clicks.
ICON Motorsports
Old Mar 26, 2001 | 01:19 PM
okay thanks..
So, what is the difference between an emergency brake and a parking brake?
Old Mar 26, 2001 | 04:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They used to call them emergency brakes when they were considered a backup to the hydraulic system, which was failure prone in its early days. However, if you are in a genuine emergency and try to stop yourself with that thing, you'll probably hit something. All they're good for is holding the car when it's parked.
ICON Motorsports
Old Mar 26, 2001 | 04:40 PM
FORD Rustangs -R- Us's Avatar
ya me and my dad have alot of fun with those things its always nice to go 65 in a 2000 6 spd trans am/corvette in a safe area and just slap that bad boy up and get a nice lil 360/180 goin
Vintageracer
Jan 10, 2020 05:33 PM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
Warlocksirix
Sep 3, 2015 12:26 PM
smooth
Aug 18, 2015 06:34 PM
Bob88GTA
Aug 18, 2015 03:31 PM
