General Emissions Question
Old May 24, 2004 | 02:52 PM
89 CamaroIROCZ's Avatar
My emissions report is as follows:
Acceptable Actual Result
NOx 1006 2494 FAIL
HC 132 164 FAIL
CO% .73 .4 PASS
CO2% 13.6 N/A
02% .9 N/A
Is it true that NOx is specific to the catalytic converter non functioning? What about HC? My choices are either the oxygen sensor is bad, or the cat... the car is running pretty well and is timed correctly and has had a fresh tune up.
Thanks,
Matt
Old May 24, 2004 | 02:57 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Looks to me like the fuel mixture is about right and all that....
Probably needs a new cat.
Old May 24, 2004 | 03:01 PM
That was my first idea, but I figured I'd ask my mentors :hail:
I'll let you know how round 3 with the NJ inspection station goes.
Thanks again RB,
Matt
Old May 24, 2004 | 11:37 PM
TheMysticWizard's Avatar
Car: 1987 Firebird Trans AM
Engine: 383 TPI...very soon
Transmission: TH700R4
NOx is also controlled by your EGR system, make sure it is operating correctly, and the passages are not completely clogged up. It may also be the cat, but I know a friend of mine had trouble with only NOx, and it turned out being his EGR system.
InfinityShade
Feb 21, 2016 01:29 PM
69 Six Pack
Oct 5, 2015 07:51 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
