just want every1s comment
Old May 25, 2004 | 03:49 PM
mory's Avatar
Car: 89 camaro
Engine: 2.8L V6
this is the same question with more added 2 it. my idle is erratic in drive at a stoplight. i see the battery gage go up and down like the car wants to lose power along with the RPM gage. ive checked the battery and its good with a DMM. ive backprobed the TPS and put new vacum lines in. i have done lots of things yall. its down 2 only 2 thing that i think. IAC not ajusted right or timing issue. what yall got 4 me? if its the IAC is this thing suppose 2 be set with somthin and how? pleeeeeeeese help. 2.8 89 camaro.
Old May 25, 2004 | 04:59 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
mory,
It sounds like an IAC problem. Mine was doing the same thing a few years ago. It turns out, my IAC was compressed and full of carbon! I don't have mine with me, but a Haynes manual tells how to adjust the IAC sensor. You might check one of those out or, if yours is real bad like mine was, replace it.
I wouldn't rule out a vacuum issue. However, I believe the IAC's are a common problem with these cars (assuming yours is a TPI motor).
Hope this helps!
Damon
Sep 26, 2015 04:29 PM
RedLeader289
Sep 23, 2015 06:50 AM
BWilcox
Sep 20, 2015 12:19 PM
amcnellis
Sep 16, 2015 04:16 PM
