how do belts go?
Old May 27, 2004 | 12:01 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
how do belts go?
i only have 2 belts, one that goes from crank, water pump, then alternator? and the other goes crank to power steering or water pump to power steering? it rubs the water pump pully a little if i put it on the crank so what do you think? thanks
Old May 27, 2004 | 02:31 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I can't remember if '85 had the flat multi-groove alternator belt like '86-'87 or not. Shouldn't matter, though.
I assume you don't have AC or A.I.R. The power steering belt only goes from crank to PS, not around the water pump.
Sounds like you have an alignment or pulley mis-match of one sort or another.
Old May 27, 2004 | 04:25 PM
bad_ta_05's Avatar
Car: 85 trans am
i can see that my crank pulley isnt lining up quite right. what coudl cause this? i used a 305 timing cover and harmonic balancer and i got it on as far as i could. maybe its not far enough?
Old May 27, 2004 | 05:59 PM
five7kid's Avatar
Perhaps. Can you see any shiny metal between the balancer & cover in front of the front seal?
Old May 27, 2004 | 06:11 PM
bad_ta_05's Avatar
Car: 85 trans am
i just tightend up the pully and now it seems to line up really nice. thanks
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
