Reman Engine & 083 heads
Old May 28, 2004 | 03:15 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
These heads are the stock L98 heads, right? Will they work with the stock TPI base?
I ask because I am ordering a stock rebuilt longblock next week and the specs on the engine are that it is 87-90 with a roller cam and 083 heads....but on a different website, it shows that the 083 heads are a 55-86 intake pattern, not the 87+. BTW...I want the 083 heads to make sure that the rebuilder doesn't swap on 350 TBI heads...what are the other cast iron L98 head #'s so I can place the order with particular head/block #'s.
Anyone answer this one?
Thanks,
Adam
Old May 28, 2004 | 03:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
083 is in fact the L98 heads. There is no other cast-iron one.
I think you mis-read, or read extra into, the information available. Mortec doesn't say that the heads have any 55-86 bolt pattern; what it does say, is "crate motor for years indicated". Which means, if you went to the dealer and ordered any of certain crate motors designed to drop into a 55-86 car, it would have those heads on it.
187 is the most common TBI 350 head to avoid.
Old May 28, 2004 | 03:25 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
RB, IIRC "187" is the 305 TBI. "193" was the 350 TBI.
Unless you are referring to putting 305 heads on a 350, in that case, yes, 187 is the head to avoid.
Old May 28, 2004 | 05:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You're right, sorry.
Old May 28, 2004 | 06:28 PM
Engine: LS3
Transmission: 6L80E
ProTorker $377 1.94x1.5, 67or76cc chamber
ProTorker $403 2.02x1.6, 67or76cc chamber
Vortec906 $375 1.94in, 64 chamber, 170 runner
059 $375 For 305cid 58cc chamber 1.94
217 $375 76cc, 12-bolt FI 87-98
083 $375 64cc, 12-bolt carb 55-86
193 $375 76cc, 12-bolt FI 87-96
This is an excerpt from Shaver Engines...www.shaverengines.com
What is the 217 head? Mortec says it is 55-86 285/300 HP crate engine head...
Old May 28, 2004 | 07:17 PM
FruityOne's Avatar
Car: 1989 TransAm GTA
Engine: One sweet modified 355 TPI.
Transmission: The kind that shifts....
Heads with casting #083 came on L98's equipped with Iron heads (all 350TPI F-bodies).
193 is the swirl port head found on TBI 350's. And the 193's suck. I know that much for sure.
Also check out what camshaft they are installing into that reman. I thought I was getting a L98 enigne because the company listed it under the *8" digit for VIN decoding.
Turns out they sent me a reman 350 with 193 heads and a tiny *** camshaft.
190/194 duration @ .050"
.384"/.400" lift with 1.5 rockers
116LSA.
How crappy can you get. I knew there was something wrong the minute my car couldn't break 87mph at the drag strip in the 1/4 mile.
15.3 @ 87mph with no traction problems on launch. All I did was drop the hammer when it went green.
But I've got parts to fix this RIGHT now. ^_^ Just waiting for the opportune moment to put he car down and do the swap.
Old May 28, 2004 | 08:19 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
That is incorrect. 083 heads were only supplied on 350s after 1986.
Old May 28, 2004 | 09:03 PM
Engine: LS3
Transmission: 6L80E
I don't think they can get me a part # on the cam...but they assure me of the 083 heads...
The reman place is Marshall engines...warranty is 3 year/100K miles...even if I install it
Old Jun 12, 2004 | 01:39 PM
FruityOne's Avatar
You can get the cam profile numbers though.
They HAVE to know whats going in it. Do yourself a favor and push until they give up the numbers. After I realised something was wrong with my car it took me about two weeks of talking with people to finally get someone to tell me the #'s on the cam profile. Then I got the supervisor and made a formal complaint that they were advertising that piece of crap 350 as a L98 replacement with the same performance.
Old Jun 14, 2004 | 07:47 PM
Engine: LS3
Transmission: 6L80E
Sounds like good advice to me...I will follow up and post results before I order the engine.
Thanks,
italiano67
Dec 11, 2016 09:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
