bad injectors
Car: 87 iroc
bad injectors
Injector drops fuels not sprays. Its not the injector because i switch them, still the same promblem. Could it be the gasket? Also is this why it ideals at 500 rpms? Its on stock TBI 92 Lo3. Where would i buy new gaskets for the injectors?
If fuel is just drooling from the injector tips instead of spraying a fine mist in a regular cone pattern, it is quite possible you have inadequate fuel pressure. You may want to replace the fuel filter if it hasn't been done recently and test pressure.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
you said you changed the injectors so to me it sounds like you have some leaking injector seals. you can get a tbi gasket & seal kit at most any parts house. take your time, watch what your doing, get all the gasket surfaces clean & make sure you change all the o-rings & be sure you don't leave any of the old o-rings in it. the o-rings at the bottom can stick in the housing.
ambainb
Apr 25, 2016 09:21 PM
