A/C Delete Questions
Old Mar 30, 2001 | 05:51 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
Hey all,
Wondering if anyone WHO HAS ACTUALLY DONE IT can tell me a little about converting an A/C car to non AC and make it look factory correct (at least at the firewall). I've been to the junkyard and found the A/C delete plate (stamped steel) but I don't know how involved this will be. is there differences under the dash? besides different heater controls, what will I need?
thanks
Clem
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, (unfortunately) auto, NO T-tops---FOR SALE---
Looking for a V8, 4 or 5 speed Camaro with NO T-tops (wanna trade?)
Old Mar 30, 2001 | 06:55 PM
Kyle F's Avatar
ITs pretty easy, all you have to do is remve all the A/C hardware under the hood and remove the plasic box holding the coil. To do this you must take two bolts out of the fire wall that are under the passenger side carpet in the front. Then install your new cover. YOu can use your old blower motor, though you will need to get a new squirrel cage to clear the firewall because the non A/C firewall cover doesn't have as much room. Wiring is all the same, just leave the wires off that connected to the A/C equipment. Then you can do like I did and modify your brackets so you don't have the hook sticking up in the air where the compressor mounted. That about it unless you want to switch out your heating and A/C controlls, which I didn't do. I don't know if you can use the same wires for it or not, but I think you could just get the new controller and mount it in the dash.
Hope this helps
FOR SALE!!!!!!!!!!!!!!!
86 Trans Am 355 TPI Rebuilt 700R4 with Corvette servo, modified valve body, and a B&M Torque Converter (2000 rpm stall w/ lock up), 87 350 block bored .30 with new crank. Reworked 305 heads with 3-angle valve job. Added in the rebuild was an SLP TPI cam, BBK 58mm Throttle Body,MSD 6A, Hypertech Power Coil,MSD Wires, 1.5 Crane roller tipped rocker arms, SLP Intake Runners and Port matching in upper intake including fully ported plenum, TPIS adjustable fuel pressure regulator @ 46psi, Hooker shorty style headers w/ Thermotech heat wrapping, Custom 3” exhaust with Flowmaster muffler and chrome quad tips, Hypertech Thermomaster Computer chip, K&N open element cone filter on modified MAF per TPIS specs, removal of A/C hardware and added a 1LE firewall cover installed. Also there has been a PST front suspension kit with Hotchkis strut tower brace added.
Stereo has 2 Clairion Pro Audio dash plates, 2 Sony 6X9s, 2 Kicker 12's in a custom Carpeted box with a custom amp rack Holding 3 MTX 280 Amps, and a MTX electronic Crossover all wired with EFX cable.
Asking $4200 with all extra Parts that are needed to fix most apearance flaws. ie Complete hatch and wing from a 91 GTA
http://geocities.com/feltsb/kyle.html
Kills:
95 Talon TSI, 96 Probe GT, 91 T/A L98, 89 RS, 86 Mustang GT, 88 Mustang LX 5.0, 92 Thunderbird V8. couple or ricers that I think were Civics or Preludes not sure what year, 95 Celica GT-S, 94 Chevy 1/2 ton 350, one of those NASCAR F150's
The Third Gen Will Never be Forgotten
Frozer!!!
Jan 19, 2024 04:55 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
redmaroz
Aug 16, 2015 11:40 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
BikeFarm
Aug 11, 2015 11:35 PM
