Funky new problem...
Old Jun 1, 2004 | 10:19 PM
87Formula4bbl's Avatar
Car: '87 Formula
Ok, had a wierd new problem arise tonight, I was tinkering around then headed to the gas station. Figured I'd blow the last few drops in the tank and have some fun, so I punched it while going down the road. Right when it downshifted and the RPM's jumped, the gauges went dead. The gauge lights worked fine (was at night) but no gauges at all (tach, speedo, voltage, etc etc), but the choke light also came on, which NEVER comes on....EVER...
Well it blew a fuse in case you didnt guess yet. So now I have a problem with blowing the gauge fuse every time I wanna get on it (situation is duplicable)?? Is this some divine sign saying I need to cool it with my lead foot before I get in trouble, or what? Seriously, does anyone have a clue/guess, or some closely related experience or situation?
WEll, thanks. I might be digging through this one for a while.
-Ben
Old Jun 1, 2004 | 11:14 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
just an educated guess but id say you have a wire grounding out somewhere ....could be wrong but like i said its just a guess couldnt really say for sure without knowing for sure what you were tinkering around with before you headed out with it ?
Old Jun 1, 2004 | 11:19 PM
Car: '87 Formula
Oh, I was just playing with the carb.
Ya, you'd think its something grounding, but....question is, what...haha. Nothing's changed since yesterday...and the day before...and the day before...and....
And yes, I got on it those days too. This is the first it's done this....wierd.
Old Jun 1, 2004 | 11:45 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I'd check to see if your alternator belt is still attached. Since you were messing around with the carb you might have bumped one of the alternator wires and it just happend to get grounded when you were testing your new adjustments. Of course you should check the fuses also.
customblackbird
Aug 15, 2021 10:16 PM
Cornholio7979
Sep 20, 2018 02:31 AM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
Blaze of Glory
Nov 20, 2001 10:18 AM
anesthes
Aug 14, 2001 07:29 AM
