Does anyone see anything wrong with mounting this here??
Old Mar 30, 2001 | 09:21 AM
scauffiel's Avatar
It's kind of hard to tell, but that is the diverter crap for the smog pump. I am looking to clean up my engine compartment when the new engine goes in and I am looking to mount this over here, over the battery tray.
I'm planning on running hose from the smog pump to the valves here; then running one hose from here to a check valve to my collector (to replace the eight lines running to my primaries); and running another hose from here to a check valve to my cat.
Heat shouldn't be an issue from the smog pump (if it is I'll go with silicon hosing) and I'm going to run some pipe from the cat to the check valve so that shouldn't be a problem either.
Am I missing anything or is there anything else I should take into consideration?
Thanks,
Steve
Steve's Trans Am Temple
Old Mar 30, 2001 | 10:03 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Nah, should be no problem whatsoever, i'm planning on doing the same thing myself eventually. I hate having anything in the way of working on my car.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
Old Mar 30, 2001 | 10:31 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
I found a much better place for my diverter valve. Sitting on the bottom shelf in my garage, right next to the dusty AIR pump. Engine bay looks MUCH cleaner now!
89 IROC with lots o' stuff
Old Mar 31, 2001 | 01:00 AM
Guest
Guest
Posts: n/a
Im with D on this one, just ditch it. Soon as you move it that far the smognazi's are gonna have a fit anyway.
GTAman
Jul 3, 2024 07:29 PM
Dyno Don
Jan 24, 2016 08:24 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
