TBI to TPI ?????'s
Old Mar 30, 2001 | 10:08 PM
RyanSS's Avatar
TBI to TPI ?????'s
Any of you guys done the TBI to TPI swap?
Anybody got pics or know if there is a manual or at least a good resource to help with the swap? I just bought a TPI system off an 89 Iroc 305, I got ECM, wiring harness, fuel lines, fuel sender, manifold, runners, plenum, TB, various nuts and bolts. The guy i got it from at the junk yard said if I needed anything else off the car i could get it.
My question is what do i take off my 89 RS when i take off the TBI, and how do i tell which wires go where? Also, what sensors do i need, besides an MAF (it was missing off the donor car)? How hard would it be to convert to SD? What other parts do i need?
Any help will be GREATLY APPRECIATED!!!
Thanks.
Old Mar 31, 2001 | 02:40 AM
Dan87IROC-Z's Avatar
My friend did this on his 89 RS last summer. Him and his dad used that TBI/TPI Swappers Guide that is sold in Summit and Classic Industries.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Mar 31, 2001 | 09:01 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
check this out
https://www.thirdgen.org/newdesign/tech/tbitotpi.shtml
1991 banditt2 #130 of 600
Project 350 TPI Banditt II
http://www.street-dawg-racing.cityslide.com
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
