Good Price on LT1?
Old Jun 3, 2004 | 12:58 AM
NorcalZ71's Avatar
Car: 94 ECSB Midnight Blue Z71
Engine: 350 TBI
Transmission: 4l60e
Good Price on LT1?
found an LT1 that is local to me on ebay, just up the freeway so ive been watching it. She is currently sitting at $600. its out of a 95 camaro, says complete an running not sure of the miles i will have to call/email the guy and find out. Depending on miles, is this a pretty good deal for an obviously used LT1? its kind of dusty/dirty, but nothing looks banged up or damaged. The guy said he was using it for a project car, but went TPI instead.
Old Jun 3, 2004 | 01:15 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
so far thats a good price.. now are you sure its the 5.7 LT1 and not the "baby" LT1? If that includes all wiring and everything I'd say go talk to the guy in person and if everything checks out offer him cash right on the spot instead of waiting for someone to outbid you.
Old Jun 3, 2004 | 01:29 AM
89RsPower!'s Avatar
Remember to give it a real good lookover.. sorry if some of this seems obvious.. look for signs of poor maintence (for example if you can wipe burnt oil film off of a rocker by sticking your finger in the oil hole) While your at it I would do every diagnostic I could think of.. static compression test, running compression test, cylinder leakdown test, you know the basic things ya check for when buyin a used engine.. verify all casting numbers (block, heads, anything else relevent).. since its still in running shape also if possible pressure test the coolant system.. defently check oil pressure with a known good gauge, and one last thing, when you pull the dipstick out feel the consistancy between your fingers.. if it feels abnormally thick its probably gear lube someone is using to cover up a problem, for example a spun bearing, or a knocking rod, etc. Also metal flakes in the oil would defently change my mind
Old Jun 3, 2004 | 02:07 AM
NorcalZ71's Avatar
Engine: 350 TBI
Transmission: 4l60e
thanks for the replies guys. actually was un aware of this baby LT1, what is it? smaller C.I? by the looks of the pictures, everythings appearance wise is ok and just needs dusting/cleaning off. just wondering also as ive forgotten, what HP and torque numbers were these things rated at in 95? thanks
Old Jun 3, 2004 | 06:25 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The 'baby LT1" was called L99 and came in Caprices (maybe more), it was a 4.3L V-8 instead of the 5.7L V-8 we all love. It looks just like the LT1.
Old Jun 7, 2004 | 11:34 AM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
The 4.3L never came in a 4th gen camaro. If it has aluminum heads (all F-body LT1's had aluminum heads) it's no 4.3l. Good find for $600 I think. Those heads alone fetch $200-$250 used.
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
