Just about to do cam change, a few last minute questions
Old Mar 31, 2001 | 06:54 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
Ok I'm going to be doing my cam change in about a week so I need to make sure I have everything down.
Can I use blue silicone where all sealer is used, like on the distributor gasket? Are there any points you guys would like to stress to me?
Tools: Crank pulley puller, lower cam gear puller, stud mount valve spring compressor, torque wrench, other various wrenches.
Gaskets: intake set (intake gaskets, distributor gasket), valve cover set, timing cover set (timing cover gasket, water pump gaskets, timing cover seal), fuel pump gasket.
Torque specs:
Intake: 35lbs
timing cover: 8lbs
timing gear: 20lbs
crank pulley: 60lbs center, 30lbs 3-outer ones
Lube: blue silicone, cam lube, assembley lube.
Let me know if I missed anything. Thanks.
1986 CAMARO Z28 ->
151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, B&M Ripper shifter, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframe connectors, all bushings are urethane, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH 3300lbs less driver and speakers Next mods-> Extreme Energy 268 cam, Holley street dom intake.
1987 TRANS AM ->
73,000 miles, 305TPI, auto, gutted air box.
Old Mar 31, 2001 | 07:31 PM
ede's Avatar
ede
i wouldn't put amy sealer on the distributor gasket, use moly lobe on the cam and lifter base, i like to use permatex high tack to "stick" the timing cover gasket in place and i use ultracopper or ultragrey RTV instead of the blue or black. i use k&w copper sealer on the intake runner gasket. use teflon pipe sealer on all the bolts that go into a water jacket.
ICON Motorsports
1st & 3rd
Frozer!!!
Jan 19, 2024 04:55 PM
apo_bailon15
Mar 28, 2016 05:20 AM
jbd1969
Aug 17, 2015 07:06 PM
redmaroz
Aug 16, 2015 11:40 PM
