Idle Problems
Old Jun 4, 2004 | 04:51 PM
kevinz85's Avatar
Car: 1987 GTA
Transmission: A4
Idle Problems
I have changed the maf (it was bad) so all my codes are gone. I still a idle problem. I tryed to set the idle speed I used the tech article, my problem is that when I try to start the car with the iac unplugg the car won't start. The car is also real rich and get 5-6 miles to the gallon. the car 87 gta 350 tpi
Old Jun 4, 2004 | 06:17 PM
DJXero's Avatar
Car: 1992 Camaro Z28
Check your fuel pressure. Poor idle and poor gas milage is a sign that you're dumping too much fuel into the cylinders. Be sure to check out your fuel pressure regulator. It's not too hard to fix and worked wonders for my idling problem.
Old Jun 4, 2004 | 06:47 PM
Vader's Avatar
If it won't start/run with the IAC disconnected (after the engien is warmed, of course), adjust the throttles open a bit more.
If your maileage is that low from "normal" driving, you may have a ruptured pressure regulator diaphragm, leaking injector(s) - including the cold start injector, a bad PCV valve, failing oxygen sensor, incorrect fuel pressure, really weak or worn ignition, or probably any combination of those and any number of things that I've overlooked.
Old Jun 4, 2004 | 06:55 PM
kevinz85's Avatar
Car: 1987 GTA
Transmission: A4
I have done new plugs wire dist. cap and rotor. The injectors all checked in @ 14 -14.5 ohms. New maf no codes but I had never thought about the fuel pressure regulator I will check that next. I also set the timing in it. And checked for vaccum leaks.
Old Jun 4, 2004 | 11:02 PM
Vader's Avatar
So, the injectors checked at 14-14½ ohms, meaning the solenoid coils are still in acceptable condition. It doesn't indicate anything at all about the flow rates, spray patterns, whether or not they are leaking, streaming, dribbling, or spraying correctly, or if they are even operating. But at least the coils are still good.
Old Jun 6, 2004 | 11:41 AM
kevinz85's Avatar
Car: 1987 GTA
Transmission: A4
ok. checked fuel pressure it was @ 38 lbs. and when it lost the vaccum it went up. thats the way its supposed to work . right?
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
