Trans Am Coolant Sensor?
Old Jun 4, 2004 | 11:52 PM
Yankeerose's Avatar
Car: 1983 Pontiac Firebird Trans Am
Engine: 305 ci V8 LU5
My 83 Trans Am has a surging problem where it would feel like it was flooding when I press down on the gas pedal and then the engine would just stall and die. Funny thing is, it would start right up after I let it sit for a couple of minutes and it would run fine until it starts warming up again and the Check Engine Light comes on and it starts surging and dies.
Took it to the shop today for a diagnostic and I was told that my coolant sensor was bad.
Sound about right?
Old Jun 5, 2004 | 08:18 AM
Vader's Avatar
You should have performed a search of the archives (for free) and saved a few bucks and the time it took to have you car diagnosed. Reading error codes is as easy as buckling your seat belt.
A failed temperature sensor can force the ECM into Backup fuel and spark mode, causing poor operation. A carbureted engine is a little less susceptible to poor operation in this mode, IF it is adjusted correctly. Many aren't.
Scan for error codes, then correct whatever problems you find. The sensor may have failed, or may somple be disconnected. You may also find other indications of problems. Did the technicians tell you what codes were found?
Old Jun 5, 2004 | 01:10 PM
Yankeerose's Avatar
I actually tried pulling the codes myself with my trusty paper clip but it just kept throwing 12 and after a few seconds had smoke coming from the dash and I wasn't sure if something was shorting out so instead of risking it, I decided to just take it to the shop for a full scan.
The tech left me a message on my machine last night that he got two codes from the diagnostic and implied that the coolant temp sensor was bad..I won't be able to get details till Monday but I'll keep ya posted.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
fonzie85
Aug 13, 2015 11:50 AM
