Question? why did activ. field service fix my idol???
Old Apr 1, 2001 | 09:28 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Ok
lateley I have been having a problem with startup idol.
usually after sitting for awhile the motor will fire right up but the RPMs will drop immediately back down and I have to gas it a few times to stabilize the idol.
after a given amount of time that seems coolant temp related the idol "suddenly" smooths out.
I have a mystery coolant leak and also a new oil leak from my pass side head to block seal.
well with the oil leak and coolant disappearing I thought I had narrowed the idol down to the head gasket and was planning to change heads anyway.
but this is where it gets wierd, today I start it up and for the hell of it bridge the ALDL for field service to see what is going on and BAM!!!
the idol snaps to attention and smooths right out. I take out the bridge and back to clug clug clug.
what can I link this behavior to??
does this indicate a possible problem with ECM or fuel pump circuit.
I know I have fuel system problems b/c i have intermittenly gotten code 54 for years and will replace the fuel pump relay soon
but this idol problem seemed to pop up lately with the oil and coolant leaks.
what gives???
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts,
SSM SFCs, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
Planning: hedman 1-5/8 longtubes, NOS 150 plate, world 305 heads, replace the "peanut"! and other susp. mods.
check it out at:
http://www.geocities.com/transam617
Old Apr 1, 2001 | 11:55 PM
rezinn's Avatar
What kind of idol leaks oil and coolant and has a problem starting up? Bad behavior needs to be attended to immediately, BAM!! BAM!! Give it to that idol good!
Sorry.. lol.. I would fix that fuel problem before you attempt anything else, you know how important fuel delivery is. If you suspect a bad head gasket, you better check that out as well. Take care of what you know is wrong first.
Vintageracer
Jan 10, 2020 05:33 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Jae992
Aug 27, 2015 09:07 AM
redmaroz
Aug 16, 2015 11:40 PM
87350gtanj
Aug 8, 2015 10:32 AM
