Code 54 after unplugged CTS
Old Jun 8, 2004 | 10:28 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Transmission: 700r4-slippin' on it's last leg
Okay, yesterday i unplugged my CTS, thinking that I could troubleshoot a bad CTS that way. (I have been informed now, that is not the case.) Well, when I tried to start the car, it flooded like a son-of-a-b****. So hook CTS back up and clear flood. Starts up fine.
Proceeded to remove my saggin headliner and adjust my door lock, and lube my power window tracks. I had the key on the whole time, but never really took notice of the little yellow SES light on the dash
So I go out today and throw the ole' paperclip in her, and get code 54. I tried to look it up, and came up with low voltage at fuel pump and/or relay (?)
Could this code have been set by not having the CTS plugged in while I was trying to start the car? Or should start trouble shooting for a bad relay/pump?
Old Jun 8, 2004 | 08:16 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
I'll include that info in the e-mail with the other info.
Old Jun 8, 2004 | 10:13 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
If your car flooded when unpluged your cts its probably working ok. When you unplug it the computer sees like -40 degrees so its gonna dump a ton of fuel to try and get it started at that "cold" temp. So id say your cts is probably ok.
Old Jun 10, 2004 | 12:59 AM
jconrad's Avatar
Car: 89 Firebird
Engine: L05 350 TBI
Thanks guys. I've finally found my Chilton's book for the car (82-92), and went over the troubleshooting for code 54. I cleared the code, and it never came back. Fuel pump energizes for appxly 2 sec. with ign on, and I was able to energize it with the fuel pump tester plug too. So I think it was an intermittent fault. Hmmm, maybe a sign of things to come.
Do you think the stock 305TBI pump would be sufficent to supply the 350TBI? Or should I look into a new pump from say a 350TPI?
I'm currently not planning on any major changes to the car except what is listed in my sig. I am looking at an 86 T/A 305 TPI also. I don't know why, the GF already has a mini-van. LOL. I think I m might need me a garage...
Falcon50
Aug 22, 2020 03:26 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
