Anyone running Edel. Elite valve covers w/ large tube runners??
Old Apr 2, 2001 | 05:10 PM
irocbsa's Avatar
I want to get an aftermarket set of valve covers and like the look of the elite series covers from edelbrock but I am worried about running into clearance problem with the set of Accel runners I just bolted on. Summitt lists the VCs as being 4 3/8 inches tall. This is about a full inch higher than stock. Not sure that will work. But when I did some measurements it looked like it would be close. I'm also worried about width. Don't want to waste 110 bucks. Thanks.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
[This message has been edited by irocbsa (edited April 02, 2001).]
Old Apr 2, 2001 | 05:17 PM
bad camaro RS's Avatar
i had the center bolt edelbrock covers with edelbrocl large tube runners no prob fit great later
1992 camaro RS w/ 350tpi
195cc AFR heads with compition port work milled to 58cc
1 3/4 hooker long tube headers
4" mufflex system
custom ED Wright chip
eddelbroc intake base and runners and much more
new best ET 13.5 @104.66 on stock heads
no times with new afr heads hoping for 12's on motor
http://www.nav.to/badass355tpi
Old Apr 2, 2001 | 08:30 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have the AS&M runners with Moroso Centerbolt vlave covers and had a problem getting the cover down inbetween the top of the rocker arm and the runner. I ended up griding away at the inside of the cover to get it down there.
MrPackstin
Oct 25, 2017 08:09 PM
gixxer92
May 18, 2017 11:20 AM
NZKnight
Oct 15, 2015 02:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
Damon
Sep 26, 2015 04:29 PM
