Swappin in a new motor, and have sevral general q's
Old Apr 2, 2001 | 08:46 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Ok, much higher hp 350, bout 430 at the crank.... the drive train issues will be solved before the motor, but here are a few concerns.
it gets fairly hot here in the summer, and i know that the current setup that is in these car won't take the extra heat made by this motor. The car will be driven daily also.
does anyone have a recommendation? oil cooler necceasary? already got an extrenal tranny cooler.
What about a fan upgrade? would it be worth it for me to setup my own shrouwd, like we did on the race car (worked VERY well) and just have a direct driven fan instead of an electric fan?
just curious if they made kits, kinda trying to also be budget conscience.
Steve
Old Apr 2, 2001 | 08:54 PM
perp's Avatar
If you overheat I'd suggest a Griffen Aluminum Radiator and a Weiand water pump
Old Apr 2, 2001 | 09:56 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
You could also get a solid fan mount instead of the POS fan clutch that GM uses. If you use headers, wrap them with insulating tape to carry heat away from the engine. Also, I reccomend getting an aftermarket heater control valve if it doesnt already have one. Autozone sells one that you turn a valve on it like a water faucet, to allow or block coolant from entering the heater core. This made about a 20* drop on my car in the summer.
1983 Pontiac Firebird SE
LG4-Based Chevy 400
700R4 Tansmission
Modified 4 Barrel Q-Jet Carb
Accel Super Stock 8mm Wires
Edelbrock Pro-Flo Air Cleaner
3.23 Posi Rear
14X7" Cragar SS/T Wheels
Clarion 45X4 CD/AM/FM Head Unit
100WX2 Amp
2 Pioneer 12" Subs in Custom Box
Third Gen Performance
"A four cylinder is only half an engine"
Old Apr 2, 2001 | 10:04 PM
fb305svs's Avatar
Ward- what your saying is more or less block off the heater core and ya get better cooling? hmm intresting. i always thought the coolant cam back on the outlet side to go back to the radiator and finish the cycle. i guess i could attempt to hook up some sort of device like what the tpi motors use...
the headers will be ceramic coated by jet hot also.. wrap might get used, but i am also gonna have cowl induction hood- which will help push some of the hot air out...
Steve
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
