Code 32
Old Jun 9, 2004 | 09:59 AM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
Code 32
I get a code 32 after driving about 100 miles or so, but not all the time. The car doesn't seem to run any worse when the code is thrown, so I don't know if there's anything actually wrong.
I'm guessing this is an EGR problem. I replaced the y-pipe recently, so there shouldn't be a back pressure issue. How do I go about diagnosing the problem? Anyone have a picture of where the EGR valve is, and the easiest way to get to it?
Or is there some other problem I haven't considered yet?
Thanks for everyone's help. :rockon:
Old Jun 9, 2004 | 10:31 AM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
My 305 threw that code the day i put headers and an exhaust on it. No matter what I did, it never went away. I have heard that the lack of backpressure can cause this, as was def. true in my case.
I really only mentioned this because you said you changed your Y pipe, is it wider? like a 3" or anything?
Old Jun 9, 2004 | 10:42 AM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
No, I replaced it with GM stock. I don't think there's anything special about it, except that they're hard to find anymore.
Old Jun 9, 2004 | 04:09 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Never mind.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
