HOT or Cold Plug?
Old Apr 3, 2001 | 07:18 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
HOT or Cold Plug?
Is Bosch +4 a hot or a cold plug? I am using those in my car for about a 8 months now and I read somewhere that the cold plugs would be better.
Also changing to 0.045 inch gap be beneficial at all or not?
Thanks.
89Iroc, 305 TPI, WC T5, 3.08 Posi, Flowtech Headers 1 1/2, Hooker Y-Pipe 2 1/2, 3 inch over the axle, Flowmaster 80, No Cat, Aluminium Driveshaft, Ported Plenum, Air Foil, MAF Screens/Fins removed, K&N, Gutted Air Boxes, AFPR @45 psi, Ram Air, Throttle Body By-pass, Bumped Timing @12, Bosch +4, MSD 8mm wires, HP Rotor, Cap and Fuel Filter, Sensi Trac rear Shocks.
Old Apr 3, 2001 | 01:25 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
depends on the plug. they have different heat codes. running too cold of a plug will cause you problems with fouling. too hot can cause detonation. i dont think theres that much performance gain from a plug heat range, getting the right heat range just eliminates fouling/detonation.
you cant change the gap on bosch platinum +4 plugs. theres 4 electrodes.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Cornholio7979
Sep 20, 2018 02:31 AM
someone972
Aug 30, 2015 12:52 AM
86IROC112
Aug 21, 2015 07:20 PM
86Base
Aug 8, 2015 01:34 PM
