Burning oil!!!!
Old Apr 2, 2001 | 05:00 PM
MurphsIroc's Avatar
Burning oil!!!!
Hey guys. for some time now I have been Have alot of smoke coming from the tailpipes. Today I went to turn the car on and a puff of black smoke came out. The car was just turned off then turned back on again. Even when it is warmed up the Car smokes out the back. white smoke. Under acceleration too. The car runs Mint, but its just the smoke. If you know what the problem is, How mch money do you think I will be charged to get it done. Is it Valve Seals? valve guides?? Please Help!!
Old Apr 2, 2001 | 07:10 PM
MurphsIroc's Avatar
ttt
Old Apr 3, 2001 | 12:55 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
Moving to general Tech, since you arent recieving speedy responses here.
snflupigus
Old Apr 3, 2001 | 08:24 AM
RGZWS6's Avatar
Do a search. There a a ton of people with this same problem. Before you conclude that this is a valve seal issue, check to see if the oil return journals under your valve cover are not plugged with poop. My car smoked like hell until I took a pipe cleaner to the little holes and cleared them out.
Try it!
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (waiting for install)
Old Apr 3, 2001 | 10:38 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
i though that white smoke was a leaking head gasket. that coolant was getting into the engine.
350 vette engine
aluminum heads
235/60R15 BFgoodriches
3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt sony amp
Old Apr 3, 2001 | 01:16 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
right, white smoke is coolant. do you have pressure in your coolant system? pull the cap and start it up. if it blows foam/air from the radiator you have a blown head gasket.
Old Apr 3, 2001 | 02:49 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Or cracked head.
db057
Apr 28, 2019 07:45 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Billgluckman
Members Camaros
36
Nov 24, 2015 07:29 PM
my86bird
Oct 23, 2015 12:20 PM
CatmanFS
Sep 19, 2015 09:00 AM
