Distrib gear from stock L03 on 350ho gm perf engine
Car: 91 Red Sled
I just did the swap about a week ago and I'm very impressed (so are all my friends). My question is about the distrib gear. I have new points and 8mm wires but the rest of the distrib is from my 145K mile L03. It was a roller engine so the cam was steel and so I'm assuming the distrib gear is brass. The new engine is the 330hp vortec 350 with hyd. flat tap. The gear looked in near new condition so I'm not worried about that but is it going to get damaged with the new cam/engine?
Thanks in advance.
, Jon (350 TBI!)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)
Thanks in advance.
, Jon (350 TBI!)
- Holley 670 TB unit w/ 1/2" spacer/adapter
- Edelbrock RPM vortec intake
- 350ho 330hp vortec crate motor
- 8" harm. balancer
- Stewart stage 2 water pump w/160 thermo
- SLP tri-y headers to full 3"
- Rebuilt trans w/ SLP shift kit
- Centerline 16x8's all around
- 36/24 mm sway bars
- Full poly bushings, even motor mounts
- SLP LCA and panhard
- Alston SFCs
- Edelbrock 3 point STB
- Global west steering brace aka wonderbar
- Eibach pro kit springs
- Bilstien high perf. struts and shocks
- All this and I still have AC
Car: 91 Red Sled
btt, anybody?
, Jon (350 TBI! getting 23mpg highway)
- 8" harm. balancer
- Alston SFCs
hey JPrevost is this the smae engine I'm looking at? https://www.thirdgen.org/messgboard/...ML/007450.html
'87 Trans Am:
(Engine)
305 TPI
160 Degree Thermostat
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)
Kenwood Excelon
'87 Trans Am:
(Engine)
305 TPI
TB Bypass
Accel Super Coil
(Stereo)
Kenwood Excelon
Sorry I can't help ya I was born with the lights turned off. hehe
'87 Trans Am:
(Engine)
305 TPI
TB Bypass
Accel Super Coil
(Stereo)
Kenwood Excelon
'87 Trans Am:
(Engine)
305 TPI
TB Bypass
Accel Super Coil
(Stereo)
Kenwood Excelon
Transmission: 4L80E/4L80E
Your old gear is fine.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
