No start
Old Jun 10, 2004 | 04:55 PM
Glens89RS's Avatar
Car: 89 Camaro RS
Engine: V-6
No start
I just replaced the starter/solenoid in my Camaro. Now, I have a no start condition. The starter enable realy clicks, but the starter does not engage. I have 12.4 volts at the battry and 13.1 volts at the starter enable realy when the key is turned to start. Where do I need to look next? Oh, the car WILL start with a jump!
Old Jun 10, 2004 | 04:56 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
How much voltage do you have at the purple wire, where it coonects to the starter solenoid?
Old Jun 10, 2004 | 04:58 PM
Glens89RS's Avatar
Car: 89 Camaro RS
Engine: V-6
12.2 volts
Old Jun 10, 2004 | 05:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Bad starter/solenoid
Old Jun 10, 2004 | 05:02 PM
Glens89RS's Avatar
Car: 89 Camaro RS
Engine: V-6
Brand new starter/solenoid. Even switched it out for a known good starter/solenoid, but still have the same problem. What has me stumped, is the car will start with a jump, but not without one.
Old Jun 10, 2004 | 05:06 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Doesn't matter if it's brand new or 40 years old
The starter/solenoid is not working
Not working == bad
Old Jun 10, 2004 | 05:08 PM
Glens89RS's Avatar
Car: 89 Camaro RS
Engine: V-6
Okie dokie, I'll replace that starter again. Hope that's the problem though, because it would not start with a known good starter/solenoid.
Old Jun 10, 2004 | 05:19 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
If it has 12.2 volts at the solenoid terminal (you're sure you've got it on the "S" terminal, not the "R" terminal, if your starter has both) and the solenoid doesn't pull in, then it can't very well be the fault of anything but the solenoid. It's just an electromagnet. This isn't rocket science, it's just car electricity, after all.
"The simplest explanation the fits all the facts is usually the right one".
—Occam, ancient Greek philosopher, from when cars had 6 volt positive ground electrical systems
And I might add, it's usually the right one, even if it's unpopular.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
