Ram Air
Old Apr 2, 2001 | 02:13 AM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
Ram Air
How well does air flow underneath our cars? Read on...
86 Z with dual snorkel...I didn't want to rob the rad of any air, plus it would have been a tight fit after cutting the plastic under the hood latch, so, after removing the charcoal canister, I cut a hole where it used to be. I ran some dryer hose from the air cleaner down to a dryer vent which I slid through the hole. The battery was in my way on the other side, but I'm about ready to move it and do the same over there. SO...here's the question...will I be getting enough air flow to achieve ram air, or should I axe the scoop and just make it a cold air set-up?
Take 'er easy, and if
she's easy, take 'er twice!!!
Old Apr 2, 2001 | 03:07 AM
86trNZam's Avatar
Car: 86 TransAm
Engine: 360 SBC 4Bolt / Bowtie Heads
Transmission: T5 NWC Manual
Axle/Gears: Torsen T2 / 3.23
Actually, I'm in the process of doing the same thing. Well on the left side anyway and will be using an air pickup supplied with the kit i've bought on the battery side.
Check out http://www.ramairbox.com/ They have some good attachments etc you may find usefull.
As for your question, looks like i'm about to find out, The way I see it is if you supply cold air under some sort of pressure it's got to be good? will keep you posted. Thanks.
1986 Pontiac TransAm - LG4 - Vin H - 5 Speed Manual - Righthand Drive - Performer Intake - Holley 4160 600 - No Cat - no emmission equip.
Old Apr 2, 2001 | 03:31 PM
Hummer's Avatar
Car: 1986 Z28
Any other opinions?
Old Apr 3, 2001 | 01:31 AM
Hummer's Avatar
Car: 1986 Z28
Old Apr 3, 2001 | 10:06 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
Why not get a ram air hood and functional ram air???
Mine should hopefully be in today....
Old Apr 3, 2001 | 09:26 PM
Hummer's Avatar
Car: 1986 Z28
The thought had crossed my mind, but I'm on a tight budget. Besides, I like my hood.
Bubbajones_ya
Jul 6, 2024 08:32 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stangski09
Nov 14, 2015 01:27 PM
edoff13
Sep 11, 2015 03:55 AM
09ave
Sep 7, 2015 06:03 PM
