305 head gasket number?
Old Jun 12, 2004 | 12:28 AM
bigals87z28's Avatar
Car: Check The Sig
Can I just use the universal 262-400 small block head gasket or is there a 305 head gasket made for the 305? I cant find it on Summit? They have a set, but its the whole gasket package which I dont need. I just need the head gaskets.
Old Jun 12, 2004 | 12:43 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A general application 350 type will suffice.
Old Oct 31, 2004 | 10:01 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
NP
Old Oct 31, 2004 | 10:03 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
again
Old Oct 31, 2004 | 10:36 PM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
A 350 head gasket will work on a 305 bore? Won't that cause some weird spots in the chamber? I know its not much, but it'd be some...
Using a 305 block and 350 heads, should I go with a 305 or 350 gasket?
Old Oct 31, 2004 | 10:52 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
If your using a 350 head you have to use a 350 head gasket, or the gasket will cover some of the chamber.
Old Oct 31, 2004 | 11:04 PM
Car: 1997 Corvette
Makes sense, had considered that but wasn't sure..
1992 Trans Am
May 10, 2023 07:19 PM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
NWAsonoma
Aug 18, 2015 05:45 PM
