My break light is stuck on in GTA
Old Apr 3, 2001 | 09:51 PM
Chet's Avatar
Car: GTA
The break light in the gage cluster is stuck on. Is there a senor or cable I can check? By the way it is a GTA digital dash if that helps. Thanks
88 GTA L98 SSM frame connectors Hotchkis STB ADS Offroad chip Transgo shiftkit All free mods
85 T/A LG4 WS6 Stock
Old Apr 3, 2001 | 10:06 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
it's telling you it's time for a coffee break just kidding. you mean Brake light
Check your brake fluid. check the pads too. when they wear and the fluid gets low in the reservoir, you'll sometimes see the light.
somebody help me out, how is the light actuated when you're low on fluid? I forget.
Clem
Old Apr 3, 2001 | 11:36 PM
R.O.B.'s Avatar
That light is also activated by the e-brake. Check to make sure the lever is all the way down, or that the switch is not stuck.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
Old Apr 4, 2001 | 07:24 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
Theres a switch in the propotioning valve, try disconnecting it. If the light goes out, either the switch is bad, there's air in the lines/leak.....
If it's still on the e-brake switch, and if it STILL won't go out maybe its the brake light switch itself (above the pedal).
Old Apr 4, 2001 | 10:16 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The regular brake light switch (on the pedal) is also hooked up to the BRAKE warning light?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 4, 2001 | 01:14 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
If 83 Z's and yours are similar: There is a switch mounted under the console for the emergency brake. Ours was out of adjustment and the brake light stayed on all the time. You could push the e-brake lever towards the passenger seat and the light would go out, but eventually come on again. You have to remove the shifter **** (automatic trannies)the top, take the console loose and raise it up off the floor, etc., to get to that switch and it's still a pain to actually get your fingers and tools to it to adjust its postion.
Z's r Best
jaridjohn
Jul 8, 2024 03:49 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Pilotrick50
Sep 2, 2015 12:48 PM
stalkier
Aug 21, 2015 01:54 AM
Omega
Aug 10, 2015 12:46 PM
