Please help! Negative battery wire location?
Old Jun 12, 2004 | 06:57 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
I have a 1988 Formula 350. I cannot for the life of me figure out where the negative battery cable screws into. I think it screws into the bottom bolt on the power steering bracket. Can someone with a Firebird and a TPI engine (Camaro battery is on the opposite side) please trace the wire and let me know where it ends (bolts into) I know this sounds stupid but I would really appreciate it. Thank you.
Old Jun 12, 2004 | 10:53 PM
treeohfive's Avatar
yes. on most third gens the negative cable goes to that bracket between a bolt. that OR on the panel near the fuel pump fuse ....either is acceptable. if you do choose to mount it anywhere but the bracket between bolts, make sure you get all the paint/grime off of the area, make sure its nice n silver to make a GOOD ground connection
Old Jun 14, 2004 | 09:49 PM
PAFORM350's Avatar
Engine: 5.7 L98
Thanks, I really appreciate the help.
Jae992
Aug 27, 2015 09:07 AM
Rakim_RS25TH
Car Audio
Aug 20, 2015 06:22 PM
Rakim_RS25TH
Aug 18, 2015 09:32 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
