need tech help
Old Apr 3, 2001 | 11:30 PM
tatertot's Avatar
need tech help
at low rpm up to 2500 rpm engin back fires , mostly when you gun it. any tips were to look
Old Apr 3, 2001 | 11:39 PM
The ODB's Avatar
what engine?
Old Apr 4, 2001 | 05:44 PM
Box of Rocks's Avatar
Spud,
What's the last thing you did before it started doing the backfire/miss ?
Or, did it just slowly go way out of tune ?
Check to see if the timing is right and then start looking for vacuum leaks - if those are okay, pull the plugs and find out which one is missing (it will be darker than the others).
If that doesn't work, write back.
Good Luck.
BOR
Old Apr 4, 2001 | 08:20 PM
ede's Avatar
ede
with no more info than you gave best thing you can do is check for codes and make sure you have a good tune up and then go from there.
ICON Motorsports
1st & 3rd
Pac J
May 17, 2020 10:44 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
