leaking injectors.
Old Jun 15, 2004 | 07:26 PM
FOX-GTA_89's Avatar
Car: GTA WS-6 1989 fully loaded
Engine: 1995 9C1 LT1 police pak XE cam
Transmission: t-5 borg warner
leaking injectors.
Again...i change my old injector because i thought they where the problem of my problem. With my new injectors when i turn the key foward to the click before start up when you hear the pump running it never stop leaking and fill my engine of gas.
and i receive a chip from pcmforless they say that it would fix my problem but with the custom chip accomodate to my new setup they dont open at all???
understand something???
Old Jun 20, 2004 | 08:39 AM
Vader's Avatar
It would be easiest to determine if the injectors are simply leaking through on their own, or are being energized to create the "leak". If you disconnect the electrical connectors from all the injectors and cycle the fuel pump, there should be no way the fuel will leak through unless the injectors are damaged.
You may need to investigate the injector wiring harness. Any unintentional grounds in the harness will cause all the injetors to go "static" (fully open) and create the problem you are describing. It is also possible that at least one of the injectors you installed is internally grounded and is causing that very same problem.
RS Reaper
Oct 17, 2018 07:52 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
