bad computer ??
Old Apr 5, 2001 | 11:43 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
bad computer ??
I have a rough idle when I start after I leave my 88 305 overnight.
it needs to be revved 3-4 times right after I turn the key or it will sputter and die.
then the idle is choppy for the next 5 mins or so then like a switch turning on it smooths right out and runs well.
recently I started it up and then bridged my ALDL for field service mode when It was idleing rough and that cleared it right up.
I dont understand what that could have done other than bypass some sensor or computer function that is causing this problem.
could someone please Identify the problem as I am unfamiliar with computer functions in field service mode.
thanx in advance
88 WS6 T/A 305 TPI--
K&N,Air foil,hypertech chip, thermostat+fanswitch
free mods, dynomax catback, urethane motor+trans mounts,
SSM SFCs, Bilsteins
very trick homemade ramair, Accel 300+ ignition system.
Planning: hedman 1-5/8 longtubes, NOS 150 plate, world 305 heads, replace the "peanut"! and other susp. mods.
check it out at:
http://www.geocities.com/transam617
Old Apr 5, 2001 | 01:34 PM
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
btt
F.I. 57 Belair
Aug 23, 2021 01:09 AM
92firebirdguy
Sep 1, 2016 07:53 AM
Johnoooooo
Sep 22, 2015 08:55 AM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
Stryker412
Sep 7, 2015 09:11 AM
