Failed emisions test...car's runing rich?
Old Apr 5, 2001 | 01:12 PM
chubb rock's Avatar
I went for an emisions test today, the car failed. Just two years ago, i went for my first test, and it failed then too. It wasn't until the injectors were replaced that i passed. The problem was that the injectors were faulty, making the car run extremely rich. This emmisions test is the same. I've only put on 14,000 Km since the first test (with the new injectors). Has anyone had this peculiar problem with their car??? I drive an 89' IROC, TPI, with a 305.
Old Apr 5, 2001 | 02:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Assuming they gave you a print-out, give us the numbers for the various readings. That may help diagnose.
Rich often means bad O2 sensor. Or a clogged or burnt-out cat will also give high readings that can be mistaken for a rich condition. A previously rich condition can ruin both components.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
6998poncho
Sep 25, 2015 02:56 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
