Help
Old Jun 16, 2004 | 05:52 AM
86z28stroker
Guest
Posts: n/a
Help
Last weekend, I took the heads off my 305 to get cleaned and to get new valves put in. Now when I put them back on car do i leave the pistons where they were positioned or do I turn it so that the piston is at #1 cylinder.
Old Jun 16, 2004 | 08:13 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Doesn't matter where the pistons are when you put the heads back on.
It will matter however when you get to the point of adjusting the valves and dropping in the distributor.
You need to know more than just #1 at TDC; there are 2 instances of #1 TDC in a complete engine cycle, only one of which is #1 firing. If you merely put the #1 piston at TDC without looking at where the cam is, you have exactly a 50% chance that the engine is at #1 firing.
Old Jun 16, 2004 | 09:52 AM
Steve89GTA's Avatar
Looking from the front of the car in, does the cam turn clockwise or counterclockwise? Always wanted to know...
Old Jun 16, 2004 | 10:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Viewed from the front, clockwise.... same as the crank.
Old Jun 16, 2004 | 10:10 AM
Steve89GTA's Avatar
cool thanks
Old Jun 16, 2004 | 01:31 PM
86z28stroker
Guest
Posts: n/a
How would i set the valves?
Old Jun 16, 2004 | 01:35 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You took the heads off without knowing what would be required to put it back together? Get a shop manual.
I don't suppose you have a torque wrench.
(Why was this on the Engine Swap forum?)
Old Jun 16, 2004 | 08:48 PM
86z28stroker
Guest
Posts: n/a
Uh oh what is a torque wrench. Of course I have a torque wrench u @******.
Old Jun 16, 2004 | 08:57 PM
ljnowell's Avatar
Wow that was intelligent calling a moderator an *******. Really is a dumb question for someone to ask considering your obvious belief in your knowledge.
Old Jun 16, 2004 | 08:59 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Geez and im on probation!?!?!?!!?!
Dont expect to be around here for too long man!
Old Jun 24, 2004 | 04:52 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
z28stroker,
Watch what you say. If you ever speak that way again to any of our Mods or Members, you'll be asking your tech questions somewhere other than ThirdGen.Org, guaranteed. You're On Probation.
BTW:
It might benefit you to take a few minutes to read the TGO Board Rules.
