Should I spend?
Old Jun 16, 2004 | 12:09 PM
snipcod's Avatar
Car: 1984 z28 Camaro
Should I spend?
Should I spend any money on a stock engine 305 with 89K miles, to get the HP up. Or should I save up for a new crate engine.
Old Jun 16, 2004 | 12:13 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You can get some speed parts, but just don't get anything 305 specific (heads, cam). If your 305 needs machine work definitely don't have that done, get a 350.
Old Jun 16, 2004 | 05:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The '84 LG4 was low compression. Anything you do to it will have a reduced effect vs. a higher compression 305.
Some things that make sense are exhaust and air cleaner. Fixing those will transfer over to most any SBC option.
The cam isn't 305 specific, but it will be flat tappet. You could transfer it over to a roller block if that's what you happened to get later, but that would be a downgrade to a roller block.
Of course, you could do the HP things on your current 305, including heads, if you'd be satisified with the results and not "need" to go with a bigger engine.
Old Jun 16, 2004 | 06:26 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
What i ment was a cam sized for that low compression 305. A bigger cam would hurt power because of the low compression.
F-body-fan
Jan 12, 2023 01:49 PM
HoosierinWA
Oct 7, 2015 10:15 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
