Switching from MAF to S/D
Old Apr 5, 2001 | 11:54 AM
Beefy89's Avatar
I've got an 89 L98 and am thinking about switching to speed density.My next major mod will be either a mini ram,or a ram jet manifold and I think both are S/D systems.My question is,what will I need?I know I'll need an S/D ECM,but will it plug into my wiring harness? Thanks
Fast as a shark~~~~~~~~~~~~~~~~~ SAVE NAPSTER!!!
Old Apr 5, 2001 | 01:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You need the ECM, the PROM, a new wiring harness (or you CAN modify your existing one, its not a plug-n-play) and a new knock sensor, along with the MAP sensor. There's probably some more I'm missing...
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Apr 5, 2001 | 04:42 PM
irocbsa's Avatar
If you want to use your existing harness you will need to get the speed density integrator and wiring for the MAP sensor from Street and Performance in Arkansas (www.tunedport.com). If you call them ask to speak to Tony. He has helped me out a lot with my swap and the few problems that I have had with my integrator. They have always been very helpful and polite. Of course you will need the MAP sensor. Post any other q's you got, I may be able to help.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Edelbrock Intake, Accel Runners, Comp Cam, Crane Gold rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Apr 5, 2001 | 08:49 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
irocbsa,
We are nearby(Savannah)and would love to see your car at the next get together. Check us out at
http://www.sethirdgen.org
John
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
BumpaD82
Feb 26, 2016 02:57 PM
tglennon11
Sep 23, 2015 05:30 PM
Nick McCardle
Sep 10, 2015 08:36 PM
