what would be making this noise?
I hear a sound that I think is valve lash but I never touched the valvetrain. I don't think that it is that because I think that it is coming from behind the water pump. Almost like the timing chain. Is this posible? Would it make noise if it's old? I have 113,000 miles on it.
88 iroc
LB9 305 tpi
k&N, flowmaster, ADS chip
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Is it Clatter ? It could be a Lifter...
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Yeah it's a clatter. Does this mean that it is bad or does it need to be tightened?
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
88 iroc
LB9 305 tpi
160* thermostat
home made ram air
removed smog pump
TB bypass
ASCD big block hood
AIM - chris1roc
Car: Firebird Formula 1989
Engine: 305, TBI
Re: what would be making this noise?
Didi you fix your timing chain problem? you said it was a clatter.
What did you do to fix the noise?
thank you
thank you
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Engine: 305, TBI
Well, I'll give you credit for trying, but if you check him out on the members list, you'll see that he hasn't been on here to post since 11-20-2002.
Old posts are like dead ends, you don't usually get any where going there!!
If you have an answer, or believe that you have an answer, just post it, it may turn out that it helps someone else!!
theshackle
Sep 17, 2020 08:26 AM
