lost rpms
Old Jun 18, 2004 | 01:04 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
lost rpms
Alright here a tech question.
i can't figure out why in the blue hell my car can't reach 5000/5500 rpms anymore at full throttle it seems to be screaming at 4500 and take forever to get there.
before i put in the msd and the rear i used to hit those rpms with ease.
could it be the rear? i still dunno what gears are in there they might be 2:7? i was told 3:23 but im not sure
or i was thinking the carb is out of adjustment or the fuel pump going
heres the rundown of what i got
350 ci 5 speed
msd 6al w/ msd internal coil
accel cap & rotor
comp cams timing chain
holley 670 street avenger w/ 1 inch spacer
edlebrock performer manifold
flowmaster muffler
msd super conductor wires
posi rear
i know it can be a bunch of things but has anyone ever had this happen or here of it?
thanks
Old Jun 18, 2004 | 01:17 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You using a factory tach? They are known to 'rebel' against you when they get into their teen years
If its not the tach, then I'd say its probably ignition related, for 2 reasons:
A) 99% of carb problems are actually ignition problems.
B) You said you put in the MSD just before this started happening.
If its not one of those, you might have a fuel delivery problem and might not be getting enough. Have you changed your fuel filter lately?
Old Jun 18, 2004 | 06:19 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
the MSD 6AL has a rev limiter,
do i happen to have it set at 4500rpm?
Old Jun 18, 2004 | 07:24 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
got the 6000 pill in there thanks
Old Jun 18, 2004 | 07:27 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
i have a autometer monster tach in there. im gonna try changing the fuel filter and check the float bowls again.
a few guys said it could be the gears are to low. i have to check to see what they are.
thanks
85 Jimmy
Sep 30, 2015 07:56 AM
wisemanz28
Sep 20, 2015 01:26 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
