Code 24 - VSS Sensor
Old Apr 3, 2001 | 06:48 PM
T/A Man's Avatar
My check engine light is always on. I plugged in my code reader and I get a reads a code 24. When I look this up it is telling me that my vehicle speed sensor may be bad.
Has anyone had to replace one of these before? All I know is that it mounts behind the instrument panel behind the spedometer so before I dive back in there I was wondering if anyone could give some tips and/or tricks that might make this a little easier, or if I even need to bother.
Also does this sensor effect performance. I have heard that it controls your timing advance as your speed increases. Is this true?
What all is effected when this sensor goes south.
I notice that my engine has a pretty limited torque curve. My engine's torque rolls off drastically between 3500 and 4000 rpm. Or is that just normal with an LG4 305?
Old Apr 4, 2001 | 06:13 AM
custman87T/A's Avatar
What year is your car...on my 87 the VSS was bad and I replaced it on the transmission not behind the dash...$40.00 part and no problem putting it in just 1 bolt.
Old Apr 4, 2001 | 08:47 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Does the Check Engine light, indicating code 24, come on while the car is stationary (and then go off after you've driven a block or two)? If so, the manual says to disregard.
JamesC
Old Apr 4, 2001 | 10:06 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Clear the SES code first and then see if it returns. If you had a scan tool, you could verify whether the VSS is actually being picked up the ecm: If the Vehicle Speed remains at 0, then its toast; if it matches the speedo (assuming your have a cable driven speedo), then it may have been triggered by something else.
If you have an electronic speedo, then your VSS must be working if your speedo is giving you the correct reading.
But clear the SES code first. Other sensor errors can trigger a BUNCH of other SES codes. That is why you really need a scan tool to figure these things out. Those code readers are virtually useless IMO.
Old Apr 4, 2001 | 05:26 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
The VSS is in the tranny my friend....not in the dash!! Unless you have an '83 or '84 then you're right!!! '85 and up, it's in the tranny where the electric speedo connector connects to the tranny!! If you don't have an electric speedo then I dunno....but that's what I know about the VSS with an electric speedo!
[This message has been edited by 86TpiTransAm (edited April 04, 2001).]
Old Apr 6, 2001 | 09:31 AM
T/A Man's Avatar
I have an 85 T/A with a 5 speed manual. The engine light stays on constantly whether I am driving or not. I have cleared the codes a couple of times and the problem reoccurs.
Old Apr 7, 2001 | 12:10 AM
burnoutrpm's Avatar
does your speedo tell you how fast your going? if so ,..the vss isnt comletely shot but, is on its way out!
89 firebird formula
356 10.5:1compression
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
GTAman
Jul 3, 2024 07:29 PM
92firebirdguy
Sep 1, 2016 07:53 AM
BumpaD82
Feb 26, 2016 02:57 PM
3rdgenkindagal
Sep 13, 2015 02:02 PM
64Chief
Sep 12, 2015 08:05 AM
