trouble code help needed
Old Apr 6, 2001 | 05:31 PM
v6-3.1's Avatar
I have a 1990 camaro RS 3.1L V6. I did a self diagnostic test, trouble code 35 came up
(IAC). can someone plese tell me what I need to do in order to in order to correct this error, also would this also explain why im getting only 8 MPG??
please reply.
THANK YOU FOR YOUR TIME
Old Apr 6, 2001 | 07:24 PM
v6-3.1's Avatar
btt
Old Apr 6, 2001 | 09:06 PM
v6-3.1's Avatar
btt
Old Apr 7, 2001 | 02:47 AM
v6-3.1's Avatar
can someone please help???
Old Apr 7, 2001 | 03:01 AM
86TransAmTPI's Avatar
ok heres the scoop.I just looked up the code 35 and heres what it says...
Idle Speed Error: The ECM has sensed an idle speed that is ±300 RPM from the desired value. Can be caused by either a faulty Idle Air Control (IAC) motor, or by one or more of the following conditions:
Carbon fouled IAC pintle bore (common)
Idle mixture off
"Hunting" idle caused by another problem
I found this info on the best dam grage on the net.
If you wanna check out the codes yourself at the site,the site is
http://www.racer-x.f2s.com/proc/codes.htm
You may also wanna check out
http://members.aol.com/mmmm999/3rd-degree/
That is also a very helpful site.And hey,while your at it,i know it may not help,but check out my TA if you want.Hope I was some help.Al in NJ
my Trans Am
http://hometown.aol.com/italianknight178/index.html
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
