Signs of bad sensor
Old Jun 21, 2004 | 09:10 PM
Badasscamaro346's Avatar
Car: 87 camaro
Engine: v8 carb'ed
Transmission: 5 speed
Signs of bad sensor
what are the signs of a bad M.A.F. sensor (besides the code)?
thanks for the help
Old Jun 23, 2004 | 09:09 AM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
the car may run better with it unpluged and or the wire looks broken. (in my experience) There is probably another culprit if you are getting a code that tells you there is too high or low of a voltage at the maf. Some repair manuals come with a troubleshooting guide for the maf and other things. The most common problems are listed first, id start there and work your way through them.
Infested
May 22, 2018 11:56 PM
bryanwood74
Sep 24, 2015 09:50 PM
GTAman
Sep 21, 2015 09:57 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
