Emmision failure
Old Jun 21, 2004 | 09:30 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
Emmision failure
I'v read alot of posts about emmision failure here on the boards. I failed the hydrocarbons. I put in a hotter thermostat today. I'v read alot of posts about putting alcohol mix and lower octang gas in my car. How much alcohol should I add to gas and how long should I wait to retest my car? Thanks. Scott
Old Jun 22, 2004 | 06:13 AM
Vader's Avatar
Do you have a working cat converter? Oxygen sensor? A.I.R. pump and valves?
How far off was the HC from the limit?
And I guess this means you got your fan working, correct?
Old Jun 22, 2004 | 12:42 PM
Car: 92 Z28
Emmissions
Funny you should mention the fan, because no, it still does not work. The converter is about six months old so is the O2 sensor and just about every other sensor on the car. The standard is 0.80 on the hydrocarbons and I was 2.09. I'm thinking with the hotter thermostat and the engine ruuning hotter now about 220 to 225 (was about 180 to 190 before) that I might pass. Car also got a complete tune-up about 6 months ago (everthying). Scott
Grant2k
Apr 4, 2016 08:21 AM
F-body-fan
Nov 4, 2015 06:13 AM
Fanatic1074
Oct 2, 2015 03:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
ban1one
Aftermarket Vendor Review
Sep 15, 2015 10:10 PM
