400 block
Old Jun 22, 2004 | 01:59 AM
boomaceboom's Avatar
Car: 1984 Camaro Z28
Engine: 305 V8 High Output
Transmission: 700-R4
400 block
are 400 blocks pretty cheap and common? can you fit 350 parts on the 400 block? is the 400 a small block or big block.
Old Jun 22, 2004 | 02:04 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Usable 400 small blocks aren't all that common, but they're out there. Because of their desirability, be prepared to pay more than you would for a garden variety 350. Parts are as interchangeable as with any other small block, but the heads will need steam holes drilled if they don't already have them.
Old Jun 22, 2004 | 02:10 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
yep things will bolt up as they will any 350. Like Apeiron said, the heads will need steam holes. That isn't too hard. And, of course, if you didn't already know, you will need new pistons and a crank (unles you run bearing spacers or something).
I could get a fully prepped 400 for i beleive $400 from my local shop.
Old Jun 22, 2004 | 12:29 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: 400 block
400's are small blocks but the 402 badges you see on some muscle cars indicate that it is a big block...basically a 396.
Most parts interchange.... if your talking a two piece main 350 and a 400. A 400 crankshaft will not interchange with a 350. The mains are larger than a 350's. They can be turned down to fit in a 350 block...now you have a 383. A 350 crank will fit a 400 block with main bearing spacers or special main bearings...now you have a 377. 400 rods (5.65" long measured from center to center) will not change with a 350's (5.7" length) without custom pistons. 350 rods in a 400 is a very popular swap and there are several manufacturers that make pistons. Camshafts will interchange between the two but will "act" differently because of the larger displacement of the 400. A radical cam in a 350 will be tamer in a 400.
Because of the larger displacement of the 400, compression will be raised on a 400 as compared with a 350 in regards to cylinder heads...and of course...the steam holes needed for the 400.
400's are externally balanced and have specially balanced flywheels/flexplates and harmonic balancers. They will not exchange with a 350's internally balanced assembly.
Everything else I can think of is a direct swap.
Old Jun 22, 2004 | 12:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
And if anyone ever offers to sell you a 400 block and throw in a set of stock 400 heads for free, get them to take $50 off the price, which is about what the irritation of getting rid of those things is worth.
Old Jun 22, 2004 | 06:53 PM
how big can you bore and stroke a 400 block. 430, 435, etc. ??? Is there any downside to the 400 blocks? How much would a basic plain block cost?
Old Jun 22, 2004 | 07:05 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
There are all sorts of problems with factory 400's. Cracked main webs, cracked cylinder walls, cracked coolant walls, etc. Susceptibility varied with year of manufacture.
How much dough ya got? A Motown block fixes all of the factory weaknesses, allows the boring and stroking you desire. More expensive up front, but doing it right once is typically cheaper than doing it cheap first and right second.
Old Jun 22, 2004 | 09:36 PM
CAMp3RO's Avatar
Car: 89 Camaro RS
Engine: sbc 400
Transmission: th350
i got lucky. one of my friends sold me his truck with a 400 and a th350 in it for $500. been running both in my car for 3 yrs now
go for a 2 bolt 400 instead of the 4 bolt. the 2's are actually stronger than the 4's due to the way the additional bolts were drilled. sbc 400 specific parts are cheap enough and easily found (my crank was in stock at the local parts store).
unfortunately still stuck with the 882's. got little/no money to upgrade, but still got tons more power than my tired old 305 had.
Hotrodboba400
Dec 10, 2019 07:07 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
anesthes
Sep 18, 2015 12:34 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
84 TA NV
Sep 6, 2015 08:02 PM
