HorsePowerTV....
Old Mar 21, 2001 | 10:54 AM
91-GasGuzlinZ-28's Avatar
HorsePowerTV....
I was wondering if any you guys saw the Saturday/Sunday episode of HorsePowerTV on TNN? Well they changed the Fuel Injectors on a 94 Z-28 and turn up the timing to get a couple extra horses. Well I was wondering where the fuel injectors are on a 91 Z-28 350 and are they hard to get too? Thanks for your time
  • Red '91 Z-28 350
  • 700-R4 Trans
  • T-tops
  • no major power
    gaining mods, K&N
    Filter, Flowmaster
    exhaust -series 80-,
    exhaust cut-outs
  • Best E.T. 15.0@93mph, Will improve that 1/4 mile time this spring.
  • www.
    hardlineperformance.8m.
    com
Old Mar 21, 2001 | 11:21 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
well i would say they are little harder to get to than a 4th gen.your injectors are mounted in the same location as the 4th gen(4 on each side of the intake)
1991 banditt2 #130 of 600
Project 350 TPI Banditt2
<A HREF="http://clubs.yahoo.com/clubs/streetdawgracing" TARGET=_blank>
http://clubs.yahoo.com/clubs/streetdawgracing</A>
http://photos.yahoo.com/tonysams72
http:/discussion-board.com/GreaterCincinnatiFBodyAssociation
Old Mar 21, 2001 | 11:22 AM
91banditt2's Avatar
Engine: 5.7 HSR
sorry what type of intake do you have?
Old Mar 21, 2001 | 06:17 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
But didn't you see? They pulled the old, injectors out, put new ones in and gained only 5hp! They probably could have had the old ones cleaned by Rick at Cruizin Performance, gained the 5hp and saved a ton of money. "Improved spray pattern" yeah right.
You need to pull the plenum and probably the runners to get the fuel rail out. Four bolts and then the two fuel connections forward by the water pump.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Mar 21, 2001 | 06:37 PM
GTAMAN63's Avatar
That Hot Rod tv episode was one of the best examples of wasted money I have ever seen. They spent around $560 on new injectors for a couple (without pressure regulator) hp gain. One of the best things they did was put on the aftermarket crank pulley. Best Bang for the buck, cheap and a much larger gain at the rearwheels.
Barry Izold
89 T/A, GTA
Modified 350/T-5
Old Mar 21, 2001 | 06:39 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
You don't HAVE to pull the runners, but it's easier and takes less manuevering
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
Old Mar 21, 2001 | 06:56 PM
Da91Bird's Avatar
Did you hear them try and play it off? They said that horsepower was not the issue, it was the throttle response they gained that made the injectors worthwhile. They added injectors, adjustable fuel pressure regulator, chip and underdrive pulley and only gained about 13 horsepower overall; with 8 of it coming from the pulley! I'm sure they're smart enough to know that it was a waiste of money. They filmed it, though, so they had to put it on the air so that they weren't waisting even more money buy throwing it away.
Old Mar 21, 2001 | 09:36 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Unless you have a misfiring or leaking injector, dont bother changing them. They'll support just about any mod you put on your car, until you run in the high 12's. Or if you run a power adder like nitrous or a supercharger.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 21, 2001 | 10:34 PM
vortech305's Avatar
I dont really think horsepower tv gives a damn if they spent 500 dollars on injectors. After all there sponsors pay for it. They just love playing around with anything they can get there hands on. Its not fair how each of them possibly own 10 cars each. I mean its not like their on a budget as some of us. Too damn bad they dont do any work on a TPI. No offense but im getting sick and tired of mustangs and big blocks. GOODBYE
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Mar 21, 2001 | 10:51 PM
GTAMAN63's Avatar
DA91bird,
Indian chief and his friend on Horse Power TV should move to comedy central. Too bad it's not thier lame jokes that are funny........ it's the way they waste money like it's growing on trees.
I remember reading an article in Hot Rod Magazine when the HorsePower TV show was still called Hot Rod TV. (same morons) Hot Rod lent them a modded Mustang 5.0 to do some work on and test at the strip. They were pissed when they got it back. It rode horrible and the mods were done poorly resulting in a lack of quicker et's. If I remember right, they couldn't get it to match it's previous et's before they sent it away!!! Shortly after, the named switched to Horsepower TV with no connection to Hot Rod magazine. I wish someone would pay me $$$$ to be an idiot!
Barry Izold
89 T/A, GTA
Modified 350/T-5
[This message has been edited by GTAMAN63 (edited March 21, 2001).]
Old Mar 21, 2001 | 10:54 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
In case anyone was interested, they did some other mods the week before.
94 LT1 6spd w/ over 120K miles on it. Stock : 231 rwhp
W/ cold air induction kit: 239 rwhp yielding a 8 rwhp gain
W/ headers, hi-flow cat, and cat-back : 261 rwhp yielding a 22 rwhp gain over the CAI alone, 30 rwhp over stock...
I don't have the exact numbers for week 2, but they got it up to what was it, 278 rwhp? Not too bad for the mods they've done.
BTW, I forsee a NO2 or Supercharger in the car's future, they did the injectors for a reason...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old Mar 22, 2001 | 07:36 AM
Da91Bird's Avatar
<font face="Verdana, Arial" size="2">Originally posted by GTAMAN63:
DA91bird,
</font>
That's no lie! It's just like those yahoos on Trucks!, they spend zillions of dollars and then act like any of us could rush out and do the same thing. They say stupid things like, "We picked up this trick little supercharger for our project [insert car name here] that'll add 1,000,000 horsepower to our SBC, and it only set us back $1,000,000! That's only $1 per horsepower!".
I forgot to mention before that they also added a throttle body to their LT1 project,with very little gain.
Old Mar 23, 2001 | 02:08 PM
vortech305's Avatar
Yeah that was funny i remember it was 2-3 hp gain. I dont think supercharger is coming soon not at least this season,dont see it in the websit. Anyway i remember back then they hooked up an 91' camaro which was called the SLP project. Where they really hooked up that car. To bad i didnt see it wish i knew the video #. Talk about lame hostes what about those guys at HOT ROD television what a bunch of GEEKS.
92' camaro
Soon to come!!!
Other car;
Old Mar 24, 2001 | 04:27 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
The plump boy is the head (or one of them) of aces (some chevelle club)....
The other one is a ford guy.....
All the 2 bit(h about is 'brand domination' so most of them are chevys (no tpi, just gas guzzlin' carbed bb's (sometimz with a blower))
They have absolutly no good info to share and make installing the multi-trillion dollar parts they push seem like a breeze (a weekend in the driveway)..........BS!
Like a spnsor wants someone to tell you all the hard probs you'll have to overcome!
They should!!!! OK I'm a machinist and worked on cars for my life. And sometimes I have troubles with aftermarket parts. (really) I mean differences in years, parts in the way, all the way up to cutting/welding t make **** fit. And they say (welding recommended but not nessasary)
get real. These guys couldn't change the oil w/o someone standing over their shoulder telling them what to do.... and these people don't have a clue either..
Old Mar 24, 2001 | 12:17 PM
Vader's Avatar
...all of which makes places like ThirdGen.org even more important to the TRUE enthusiasts.
Later,
Vader
"I'm'a do Things My Way - It's My way or the Highway."
Adobe Acrobat Reader
Old Mar 24, 2001 | 03:02 PM
CamaroMike's Avatar
VADER, YOU DA MAN!
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Recently Ported Heads, Installed Larger Race-Flo Valves and RPM Air Gap Intake (No new times)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
The Bowtie
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Mar 25, 2001 | 10:51 AM
vortech305's Avatar
Yes all that is true but im sure im not the only one when i wanna see for ONCE a Tuned Port Injection from a third generation camaro/firebird getting work done to it.
Old Mar 25, 2001 | 01:44 PM
Biochem's Avatar
Car: 2002 SOM z28
I think they did work on a 87 once a few years ago, but all they did was some suspension stuff. I could be thinking of Shadetree Mechanic though...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
Old Mar 25, 2001 | 01:50 PM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
i dont know how you guys feel about the guys from shadetree mechanic(now crank and chrome) but they are still doing the basic maitenance sown to earth **** that we all do to our rides. i love that show and cant stand the others where they say things like "it'll only set ya back about 1500 dolars" i dont know about you guys but i can just drop 1500 bucks like that
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
CHECK OUT MY SITE http://www.fbody.com/members/bigdaddyshawn/
MUSTANGS SUCK
Old Mar 25, 2001 | 03:37 PM
GTAMAN63's Avatar
83CamaroMan,
I agree with you. The Crank and Chrome show is much better than Horesepower TV. They even have a "coffee break" - a tradition in our garage, expecially in the early morning hours!!! A possible Horsepower TV quote - "And it's easy on the wallet! It'll only set you back a COOL $300.00 for this "high performance" shift ****. Surely it will drop your et half a second in the 1/4 mile........."
Barry Izold
89 T/A, GTA
Modified 350/T-5
[This message has been edited by GTAMAN63 (edited March 25, 2001).]
Old Mar 25, 2001 | 05:17 PM
84TransAm's Avatar
And the all the shows leave out the part where you cut your knuckles and start cussin'. Which is usually 80% of the job!
--Steve S--
1984 Trans Am 305 LG4, 5 speed
Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance
[This message has been edited by 84TransAm (edited March 25, 2001).]
Old Mar 26, 2001 | 08:07 AM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
I have to say most of the shows are for ENTERTAINMENT not technical expertease(sorry I can't spell). I agree with evertything about HP tv and a couple years ago on Shadetree they installed new body panels ona pickup, there quote was something like this "Were using this handy dandy plasma cutter today" Damn I don't know about you guys but I just don't have enough cash laying around for a torch let alone a PLASMA CUTTER. Well I'm done griping about TV shows.
John
Old Mar 26, 2001 | 01:10 PM
vortech305's Avatar
ill never be done mainly cause of that episode on shadetree mechanic where they modidfied a red 93 mustang. WHy not do a freakin TPI. Im sorry im just really pissed cause i havent seen a TPI being done yet. Please for the love of god someone show a TPI IN A THIRDGEN CAMARO/FIREBIRD and not big blocks and carbs.
92' camaro
Soon to come!!!
Other car;
Old Mar 26, 2001 | 03:59 PM
Omar's Avatar
I also like Crank and Chrome. They seem to do more "starting out" mods and maintenance than the other shows.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Mar 26, 2001 | 08:14 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Heh, start emailing them, maybe if we get over 3500+ people to email people on horsepower TV or crank and chrome they'll actually maybe glance over one of the emails.....erm...heh, probably not!
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
Old Mar 26, 2001 | 09:57 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
I saw the ep of Crank and Chrome where they dynoed the little red mustang, and ran it down the 1/4. Not a bad ep, but every other one I've seen has been like standard work on a crappy car. This last week they did the 60 thousand mile tune up on a Yukon SUV. Can you say freakin' boring? I don't like that show very much, I'd much rather watch HP TV, even when HP TV is on one of their many ***** or equally lame (a van buildup???)binges...
HP TV did a nice buildup on a TBI firebird, but the moron's left the peanut cam in there, which like totally defeats the purpose of a good intake/exhaust buildup fest...
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Old Mar 26, 2001 | 10:49 PM
vortech305's Avatar
ur right and with all that mods they inlcluded w/ nitrouse they had 224 hp at the rearwheel. damn why are they such hard headed idiots.
92' camaro
Soon to come!!!
Other car;
Old Mar 27, 2001 | 09:59 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
and where the hell are the back to back dragstrip tests. Who the **** cares how many HP we picked up. I wanna see #s that actually mean something in the real world.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Old Mar 27, 2001 | 10:00 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
ps, somebody should email themthis link.
Old Mar 27, 2001 | 01:33 PM
Damon's Avatar
.......and exactly how did they "turn up the timing a little" on a 94 LT-1??????
Can't just give the distributor a little twist like in the old days!
Old Mar 28, 2001 | 02:56 PM
vortech305's Avatar
ah well this season is almost over i believe we have 2 more shows to go then its back to last years boring episodes. Does anyone know how next seasons episodes gonna be. Betcha more big blocks and carbs,and imports,and mustangs and all that crap.
P.S is anyone else getting bored of that stupid pro pony touring project.
92' camaro
Soon to come!!!
Other car;
Old Mar 29, 2001 | 07:34 AM
JoelOl75's Avatar
Next year for Hotrod tv will probably be all hondas, acuras, toyotas.....
PUKE
Old Mar 29, 2001 | 12:22 PM
Da91Bird's Avatar
They are definitely going in that direction. Remember that stupid project they did with the red CRX? I just don't understand why people would want to do performance mods on those cars. For the amount of money you have to spend to get them into respectable speeds, you could have built a big block F-body funny car that'll run .3's in the 1/4 mile.
A guy at work had an import magazine one time and I started flipping through it. They had this huge article about installing an Acura cylinder head on a Honda (I realize Honda makes both engines, but that's how they set up the article). It cost a couple of thousand dollars and took many hours. When they were done, they bragged about picking up 3 horsepower! It just doesn't make sense.
Go Air Force!
Old Mar 29, 2001 | 12:41 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
yeah, theyll swap out their camS for 3-4 HP.....what a joke
Old Mar 29, 2001 | 01:01 PM
theformula's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Da91Bird:
</font>
Remember yo, it ain't about just speed..it's about da 22 inch rims too yo ....
you gots da have dat sheet to be down wit da homies. Yo peep dis, my ride gots mad pedal yo. yestaday i beats one of dem new corvettes
Old Mar 29, 2001 | 01:18 PM
Ovrclck350's Avatar
<font face="Verdana, Arial" size="2">Originally posted by vortecfcar:
</font>
I just did.
Oh, for the formula..... WORD.
[This message has been edited by Ovrclck350 (edited March 29, 2001).]
Old Mar 29, 2001 | 01:27 PM
vortech305's Avatar
hey ovecclick how did u do that happy face shooting a gun???
Old Mar 29, 2001 | 01:30 PM
theformula's Avatar
oh my god!
lol Ovrclck350
Old Mar 29, 2001 | 02:57 PM
Ovrclck350's Avatar
it was [.img]http://cwm.ragesofsanity.com/s/net5/uzi.gif[/.img] without the periods in the img statements....
Old Apr 2, 2001 | 06:15 PM
vortech305's Avatar
this weeks episode sucked *** . How are u gonna compare carbs w/ fuel injection. Both mopar and ford used carbs while the pathetic 502 big block was in the mid 300 hp area. What a sad saturday. Anyone else pissed here besides me.
92' camaro
Soon to come!!!
Other car;
Old Apr 2, 2001 | 07:19 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
What kills me is no matter what they're doing, they're hands are always clean, and they NEVER show any effort in removing a bolt. Ever see a header or exhaust manifold bolt come out with finger pressure on a 3/8 ratchet?? From the git go?[sic] Those clowns are hilarious. Shadetree does the same thing, but as was mentioned before, at least they do more things that most people can do any day in thier garages.... those guys on HPTV are idiots, and if you ever saw the end of one of thier shows where they were showing all the bloopers (Soupy Sales comedy routines and all) you probably ran to the john and puked like I did.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, Wonderbar, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Member - The Tidewater Trans Am Club, Norfolk VA http://www.geocities.com/ttacva/
Old Apr 2, 2001 | 11:30 PM
  #42
vortech305's Avatar
yeah they suck at least they stick with what show they are(sorry im drunk) anyway shadetree mechanic does a stupid episode on putinggg an ladder holder on a 4x4 who cares thats a show for trucks they all suck excuse me gotta throw up.
Old Apr 3, 2001 | 12:52 AM
  #43
auxout's Avatar
Car: 92 RS
Engine: VSux
Transmission: Flux Capacitor
This isn't a TV show but I find the terms they use to describe the money they spent very hilarious... this is from super chevy they do a ZZ4 Engine swap into an 86 Z28 which had a "tired and gutless 305"
"This author purchased his fairly clean '86 Z28 for a meager $2,000..."
[Pocket Change right ]
"Fortunately you can still transform the car into a great performer without breaking the law--or breaking the bank."
The article is pretty vauge and only gives you a part # no idea of the price (already figured it was way more than I had) so for the hell of it I looked it up, $4,771.25 for the ZZ4 Kit from GM. Now I suppose if you look at the whole picure 6,771.25 for the whole setup it's not breaking the bank and it's cali emissions legal... I just find it funny they didn't put what they paid. (this was online so maybe they did in their mag) But hell anytime someone wants to toss me a meager $2000 let me know!
85 POS
92 RS
[This message has been edited by auxout (edited April 02, 2001).]
Old Apr 4, 2001 | 04:56 PM
  #44
vortech305's Avatar
Old Apr 5, 2001 | 09:50 PM
  #45
RICHRAD's Avatar
How about that " Dream Car Garage" Now there's an outlet for those of us with a little f-body classic blood.
Old Apr 6, 2001 | 12:56 PM
  #46
vortech305's Avatar
Dream car garage??????????????????????
92' camaro
Soon to come!!!
Other car;
Old Apr 6, 2001 | 01:59 PM
  #47
Axle/Gears: 3:08
yeah what is DREAM CAR GARAGE????????!!!!! im still a shadetree mechanic fan
FLAT-TOP PISTONS
MILD CAM
B&M RATCHET SHIFTER
MUSTANGS SUCK
Old Apr 6, 2001 | 04:30 PM
  #48
RICHRAD's Avatar
Wednesday or Sunday nights SPEEDVISION
Old Apr 6, 2001 | 07:15 PM
  #49
Axle/Gears: 3:08
looks like i have to call my cable company...........................
Old Apr 7, 2001 | 07:26 PM
  #50
vortech305's Avatar
I hate saying it but Shadetree Mechanic sucks A$$. Why u ask. they only work on vehicles to their liking(dodge turbo diesel),(putting ladder trailer on a ford truck),(doing a 60,000 mile maintenece. No offense but their morons they should stick with modifying American muscle and sports cars.
92' camaro
Soon to come!!!
Other car;
