EGR confusion
Old Jun 24, 2004 | 08:18 AM
91z28350's Avatar
Car: 1991 z28
Engine: 5.7
EGR confusion
Hey guys Im kinda paranoid now after reading how the EGR crap works. I have no lines running to my exhaust because i had the cats removed and straight piped. What would be in my best interest to put a block off valve or run the lines back into the exhaust? I heard the ecm will retard timing and stuff and thats no good.
Thanks!
Old Jun 24, 2004 | 08:20 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Your car doesn't use plumbing to the exhaust for EGR. It's in the heads and intake base.
Removing the cat has nothing to do with EGR.
Old Jun 24, 2004 | 08:25 AM
91z28350's Avatar
Car: 1991 z28
Engine: 5.7
Then what purpose do the lines serve that were running to the cats? And i nthat case would removing all the smog crap mess with the ECM?
Old Jun 24, 2004 | 08:27 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
AIR... air injection. The purpose of the cats is to finish burning any unburned or incompletely burned fuel; obviously oxygen is required in order for that to happen; those lines supply fresh air to the cats.
I would not recommend just hacking stuff off your car; it's not impossible that someday it will be required in your area in order for you to continue to be able to license the car. It isn't costing you any power, just as a cat wouldn't. Hacking is rarely a good idea.
Old Jun 24, 2004 | 08:34 AM
91z28350's Avatar
Car: 1991 z28
Engine: 5.7
Wow I really was confused.....Where do those lines from the cats go to then? Smog stuff? One is just dangling there and the other is gone now.
Old Jun 24, 2004 | 08:38 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Air injection system.
The "smog pump" pumps air into a valve, which sends the air to the manifolds when the motor is cold and to the cats through those lines after the motor warms up.
Old Jun 24, 2004 | 08:39 AM
91z28350's Avatar
Car: 1991 z28
Engine: 5.7
You rock thanks man
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
