Electric Fuel Pump question
Old Jun 24, 2004 | 10:43 PM
Archie's Avatar
Car: 89 Camero Iroc-Z
Engine: 5.7 - 350
Transmission: Automatic
Just one small question. We recently replaced the electric fuel pump in my son's 1989 Iroc. I notice that after shutting the car off I can still hear the pump running a few of seconds afterward. I never notice this before the old pump with bad. It this normal for the pump to keep running, even for just a few seconds after the engine is off?? And if not, what could be causing the pump to do this?
Old Jun 24, 2004 | 11:00 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
should run for 2 seconds with key on engine off, then 2 seconds when you shut the car off to retain fuel pressure for next startup
Old Jun 25, 2004 | 02:38 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
2 seconds? thats it? mine runs for up to i'd say... 15 seconds some times, is that a sign its on its way out?
Old Jun 25, 2004 | 03:11 PM
Morley's Avatar
Might be the relay sticking
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
