compression
Old Jun 25, 2004 | 12:53 AM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
compression
How much compression would I lose going from the 58cc heads I have on my 305 to heads with 64cc?
Old Jun 25, 2004 | 03:31 AM
Morley's Avatar
You'd go from 9.5:1 to about 9:1 depending on the thickness of the gasket you use.
Old Jun 25, 2004 | 11:38 AM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
thanks
Old Jun 25, 2004 | 03:59 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
figured it might be a little more then that
but don't hold me to that I'm just guessing
how come the larger head if you don't mind me asking?
Old Jun 25, 2004 | 05:06 PM
Morley's Avatar
the actual loss will be about .7:1 with a direct swap (same gasket compressed thickness, but if he goes with a little thinner gasket it will be around .5:1.
Now if he were to use a .016" shim gasket the loss would only be .1:1 or less
Old Jun 25, 2004 | 05:23 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
ok I was just too lazy to do math :-)
but was just assuming it would be more like 1-1.5 loss
Old Jun 25, 2004 | 05:47 PM
gtaeric's Avatar
Car: '88
Engine: 305tpi
Transmission: t-5
Yeah the reason I'm wondering is I'm considering putting vortec heads on my 305tpi. If I only lost about half a point of compression, thats pretty negligable. Now its just $$$...
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
