Strange oil leak
Old Jun 26, 2004 | 01:37 PM
Hollis's Avatar
Car: 82 Camaro Z28 Indy 500 Pace Car, 98 Firebird
Transmission: TH200
Strange oil leak
Is it posible for oil to leak from the bolts for the fuel pump? Ill wash it all off and thats where it seams to come back from.
Old Jun 27, 2004 | 11:25 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
yup. behind the plate that the fuel pump mounts to is the pushrod for the fuel pump and it uses the engine oil in there to keep everything lubed. id take off the pump and the backin plate clean everything and put it all back to gether with a new gasket. watch out though becuz the pushrod will fall out when u take off the backing plate
Old Jun 27, 2004 | 12:06 PM
Hollis's Avatar
Transmission: TH200
Allright thanks :hail:
Old Jun 27, 2004 | 12:14 PM
Hollis's Avatar
Transmission: TH200
Oh, by the way if im leaking oil there am i also leaking fuel?
Old Jun 27, 2004 | 03:22 PM
krly79's Avatar
Car: '93 S10 Short bed standard cab
Engine: 383 Stroker
Transmission: 92' stage 2 700r4 w/3600 stall
you won't leak fuel from there just because you leak oil.
Hotrodboba400
Dec 10, 2019 07:07 PM
Fronzizzle
Sep 8, 2015 12:10 PM
SG91camaro
Sep 5, 2015 10:27 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
