Code 34,MAP Sensor Problem
Car: 92Rs 25th ann
Engine: 305 TBI
Transmission: auto
I have a problem,my 84 Z28 keeps showing that the map sensor is bad or something,i reset the computer and it still shows up,whats goin on,i think i know where its at on the drivers side on the firewall
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
i had this problem this morning and couldn't figure it out, so i started checking things under the hood. what i found was that i forgot to reconnect the weatherpack conncector to the map sensor itself...when i connected it, the code went away. this may not be your problem, but it is worth a shot to check it out.
Car: '81 Camaro (Modded), '89 IROC cvrt (Stock), '00 GMC Jimmy
Engine: Modded 350 in '81, 305 TPI in '89 IROC, V6 Vortech in GMC
Transmission: T-350 in '81, 700-R4 in IROC
i'm having the same problem in my 89 iroc 305 tpi, it says something about the map sensor having too much vacuum but idk where the sensor is..i'm gonna try to find out where it is and just hope to get lucky whiile switching vacuum hoses
Engine: 5.7L TPI
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
